davidwatsonok
Advice on Mk4 rear caliper upgrade
strangely enuff, i did the same, i was just going to overhaul the rear brakes and ended up shotblasting and painting rear beam, new calipers, discs, bearings, hoses etc etc, i just couldnt leave it alone :)
I'm going to do the same to my golf when I find the time. I have all the bits there to do it just need to get stuck in.
I will be taking my chances with a pair of secondhand calipers though, that's for sure!
Guys,
just ordered a pair of rearMK4 calipers from a breakers - I understand
there were two types early and late, the early ones being smaller than
the later ones. Do we know which ones are compatible with the Corrado?
STORM 2, I only know of one type on mk4's but there are variants...
Unless they are very cheap and very good condition I would buy these new....
too late now - just paid - apparently in good nick but i f I have any doubts I'll stick em up on egay
callipers also avaialbe brand new here,,
brand new same thing pretty sure they are the golf ones,, seem to have an extra return spring on them too hmm interesting,, take a look for yourselves,,
http://www.rallydesign.co.uk/catalog/pr ... s_id=10563
when i did mine a year or so ago i got a set off of a seat ibiza Cupra,, come already powdercoated red,, still not 100% happy with teh handbrake but i still have the original handbrake cables in there i must replace them sometime,, mind you havent worked out how to het the cover around the handbrake handle off yet,,,,
and as for the conversion hoses i got them from goodridge direct,, just tell them you are a trader and they will sort you out,,
Guys,
I would imagine it's the smaller ones you want.
The anniversary model Mk4 GTIs, Audi TTs and Octavia VRS models used a different caliper afaik as they had a bigger vented disc on the rear. Any caliper from an ordinary Mk4 should work fine. I've taken them off 1.4 petrol and TDI models and they were all the same.
I'll have to see when they arrive - I asked for the ordinary 2L ones .
BTW they cost £45 for the pair +VAT +Delivery = total £75
How many flexible hoses are there on the back of a Corrado VR6 is it 2 or 4?
2 hoses from the body of the car to the rear axle (about 5cm long, tops) and another 2 from the axle to the callipers.
Then obviously another 2 on the front :)
So if you go for Goodridges, with Mk4 Calipers can you get a set that fits all of those. Presumably the Mk2 to Mk4 set still has the same short hoses in, just the caliper hoses are different. Hope this is clear!
I do believe so, but I bought mine all at different times, so don't know what the Goodridge part number is for a kit like that
