Mk2luke16v
Rear ABS sensor
The question's probably been asked before, but would a mark 3 Golf rear ABS sensor fit a Corrado?
If not, any ideas where to get one from other than the stealership where they will rob me??
Cheers
Luke
What model/year's your corrado? I think later corrado's have the same sensors as mk3's, on the front at least. I get mine from German & Swedish, they will tell you if they are the same as the mk3. The abs rotors might be corroded or have come loose too, I derusted & painted mine when I changed the rear discs.
It's a K plate 2litre valver. the guy in GSF said they "might" be the same but wasn't 100% sure. Derusting and cleaning up has already been tried..got it working for about a day then it gave up again!
