Fez
G Charger Rebuilds
Does anyone know if there is anywhere in South Wales or Bristol area that refurb and port and bore out to stage 4.
If so can you let me know the website add's and if they come recommended.
Cheers,
Fez
Ps. long time no see chaps :D
you could allways drop your unit into Dubusiness in cardiff as they are an authorised outlet for g-werks and can sort it for you.
G, dont suppose u no there address?
If so can u post it or pm it to me. Also, if I took it in could they tell me whats wrong with it?
Cheers,
Fez
I moved your thread , to the suppliers section :lol:
Dubusiness have also moved, to Llantrissant , i don't know the address tho.
Fez, can highly recommend Gwerks for all things G. Definatly your best bet, especially if you can get it done through dubbusiness!
darren, respect to you for offering up the names of other places to go. :notworthy:
where 2?
coedcae lane industrial estate pontyclun,M4 junction 34,
about 20 mins drive from where you live mate.
come off at 34 head for llantrisant,straight throu two sets of traffic lights,first left at round about,straight across the next,straight on at lights,first left here at next roundbout,yet another round about you need to take the second exit to codecae lane,but be carefull this looks like the first exit so take it "oposite loreal's factory".
50 yards turn left right by TNT parcels, small few ind. units,first right and its on your left.
regards kevin
thanks for all your help guys. Satrs the lot of ya. :D
I was reading another thread earlier on the forum, so I am gonna check if anything is lose first (fingers cross).
Anyways, how much will have the charger taken to a stage 4 set me back, roughly?
£500 i believe.
[edit] stolen directly from g-werks.co.uk
G60 G-lader Full service porting/polishing
In addition to the above work this service includes porting/polishing of the internal chambers and exhaust of the unit this helps to aid air across the non oil fed top shaft bearings and to increase the flow of air through your unit.
£500 Inc VAT.
will keep in touch then when I've had chance to get the charger off and see if theres any play in the bearing
Please forgive my thickness as I know jeff all about engines.
But what actually will a stage for do for the C? More BHP, Torque, etc?
