17corrado16v 0 Posted March 21, 2006 noisey tappets is it expensive???? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted March 21, 2006 I don't know - I've never bought noisy tappets before!!! Are they more expensive than quiet ones????? Quote Share this post Link to post Share on other sites
17corrado16v 0 Posted March 21, 2006 haha we have a comedian!!! im mean how much to repair them? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 21, 2006 Have you tried using a different oil? (welcome to the forum by the way) Quote Share this post Link to post Share on other sites
chrishill 0 Posted March 21, 2006 try some engine cleaner before paying to have them swapped, it can sometimes dislodge muck around the tappets and allow them to adjust properly. Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted March 21, 2006 :lol: nice one Blue_Joe, 17corrado16v, http://www.vwspares.co.uk/corrado.php try this mate Quote Share this post Link to post Share on other sites
jimmy83 0 Posted March 21, 2006 depends which engine! I'm having mine done at stealth soon on my 2.0 valver when kr cam goes in. I think vince said approx £80-90 for 16 new followers. Quote Share this post Link to post Share on other sites
17corrado16v 0 Posted March 21, 2006 no would that sort the prob? do u have a oil in mind? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted March 21, 2006 haha we have a comedian!!! im mean how much to repair them? Depends on if you can do it yourself. Depending on which ones you need they are between £4.50 and £6.50 + VAT each from GSF Quote Share this post Link to post Share on other sites
17corrado16v 0 Posted March 21, 2006 try some engine cleaner before paying to have them swapped, it can sometimes dislodge muck around the tappets and allow them to adjust properly. where can i get this cleaner? Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted March 21, 2006 Cleaner... Depends on the age of your car... I went to a local shop and was told the more extreme ones (like STP) aren't too nice for older engines. So went for a more gentle option. can't for the life of me rember the name of it though. Sorry... Just pop to a local car shop and see what they have. Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 21, 2006 17corrado16v, try sending This guy a PM , he'll be able to tell you the best oil to suit your needs, and can also supply it at a good price :lol: Quote Share this post Link to post Share on other sites
Geo 0 Posted March 21, 2006 Step 1. Buy Wynns Hydraulic Lifter Treatment and try that. Probably a good idea to do an oil change as well if it hasn't been done for a while. Which leads us to: Step 2. Try a different oil. Sometimes with an old 16v engine a 15W/40 grade oil is better than a 10W/40. Step 3. If the tappets are only noisy when the engine is hot then do an oil pressure test, sometimes the tappet noise is caused by not enough oil pressure getting to them rather than a problem with the tappets themselves. And then if that checks out ok: Step 4. Replace the tappets. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted March 21, 2006 could try soaking the tappets in oil first before a refit if you wanna try n save a few quid Quote Share this post Link to post Share on other sites
17corrado16v 0 Posted March 21, 2006 ok cheers guys Quote Share this post Link to post Share on other sites
corradophil 3 Posted March 21, 2006 Have a look in the engine section on Club GTI's forum, there is a thread about rebuilding them, and people seem to be getting good results. Quote Share this post Link to post Share on other sites
rolex 0 Posted March 22, 2006 Step 3. If the tappets are only noisy when the engine is hot then do an oil pressure test, sometimes the tappet noise is caused by not enough oil pressure getting to them rather than a problem with the tappets themselves. And then if that checks out ok:. how would you go about doing this? Quote Share this post Link to post Share on other sites
Geo 0 Posted March 22, 2006 You need an oil pressure tester gauge, either buy one yourself on ebay (pretty cheap) or get a garage to do it for you. Basically you unscrew the low pressure sender, screw in the gauge and read the pressure (should be 2 bar @ 2000rpm with the oil @ 80deg) Quote Share this post Link to post Share on other sites
