sciroccotune 0 Posted March 23, 2006 as above guys and girls, i want to fit my phone/gps charger in to the car so i dont have to use the lighter sock. any ideas? Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 23, 2006 Where do you intend installing it on the dash? I thought the lighter was 12v anyway??? Quote Share this post Link to post Share on other sites
carpy25 0 Posted March 23, 2006 your charger will reduce the voltage from 12v to 5v so all you need is a lead with a lighter socket on the end (you can get these in most accesory shop) wire that to a fused 12v supply and an earth and plug your charger in then hide the lot behind the dash just leaving the end that goes into the phone out Rob Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 23, 2006 Personally, I'd look at routing the wires behind the centre console and splicing them in to your ashtray supply and earth, it'll always be on then (if thats what you want of course?) Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 23, 2006 Let me get this straight... You have a 240vAC->5vDC charger for a device that you want to be able to use in the car? If so you won't be able to use the 12v lighter socket without a DC-DC converter anyway. To be honest I'm not exactly sure what you're asking but once it's clear I'm sure there'll be a simple solution. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 23, 2006 As far as I can make out, its an in-car charger Quote Share this post Link to post Share on other sites
carpy25 0 Posted March 23, 2006 Bcstudent picked up what i missed :oops: if it's a house charger that you want to fit 240v ac to convert to 5v dc then an inverter is the only way but it would be cheaper to get a universal car charger and do what i said in my first post Rob Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted March 23, 2006 ah sorry guys! i should be more clear :oops: . Carpy25 had it right. I want to wire the car charger in so its all nice and behind the dash. If i can just wire up the lighter insert to a fused supply then thats great, ill do that. Ill just use the wires from the lighter socket as stan says :-) sound good? Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 23, 2006 Mentioning the 5v part was what made it confusing. If you're just looking to hardwire a 12v charger in then there are a few options; you've mentioned two of them. I'd be inclined to sort out a seperate power supply for the charger rather than render the cigarette ligher redundant myself. You just never know when you may need it. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 24, 2006 It wont render it useless if he splices it in, or solders it, as the voltage will just be shared on a parallel path. Quote Share this post Link to post Share on other sites
