turbomagikz 0 Posted March 25, 2006 ok , i would like a little help ? if possible. :roll: i only use my 95 vr6 1 day a week , its only done 70K , but 6 days a week it stands in my yard in the "northeast" damp wet snowy weather ! when i first take it out it has a bit miss -n- fart on ? as i go from 1st to 2nd gear it misses a beat ? so ive just replaced leeds & plugs ? still the same when damp , but :roll: ok when its dryed out after a good run . so could it be COILPACK ? if so where can i get a new coilpack at a good price ? & what is a resonable price for a new coilpack . thanks mark :oops: Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 25, 2006 I paid around 70+VAT from Vag about a year ago, but they go on ebay all the time for around £50 TBH thought here are loads of things which may be causing the symptoms you describe from temp senders to cam position sensors - I would try and hook it up to VAG-COM first before spending your money on coilpacks Quote Share this post Link to post Share on other sites
turbomagikz 0 Posted March 25, 2006 cheers storm 2 . i called uroparts today & they quoted me £171 plus vat? this cannot be right ??? . thanks Quote Share this post Link to post Share on other sites
turbomagikz 0 Posted March 25, 2006 where & how would i find vag-com in north east england ? Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 25, 2006 there a thread on this forum listing users with VAG-COM who may be in your vicinity and could help you out Quote Share this post Link to post Share on other sites
double-6s 0 Posted March 25, 2006 either ask your northern buddies on here for a lend, or go to any veedub dealer/specialist/garage mate. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted March 25, 2006 Cheapest ones are from GSF for £120 ish Quote Share this post Link to post Share on other sites
NickRStorm 0 Posted March 26, 2006 I've had the exact same problem this week & as a long-time VR owner, I've learned the difference between damp & a knackered coil-pack. 99% of the time, it's damp & the cure is easy: 1) Remove all plug leads from coil-pack (note down fitting order!) 2) Spray a generous amount of brake cleaner over the coil-pack 3) Clean thoroughly with a clean rag using more brake cleaner & allow to dry 4) Ensure there is no crud inside and around the ends of the plug leads before re-fitting 5) Coat the whole thing liberally with WD40 & away you go :) When the coil-pack goes, it doesn't ever run right and sounds & feels horrible as you're only running on 4 cylinders. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 26, 2006 There *is* an intermediate stage of coil pack failure, where the casing cracks. This will allow it to run "ok" sometimes but not others. I'm afraid that just like everything else in Corrado land, this is not quite so black and white, either ... Quote Share this post Link to post Share on other sites
turbomagikz 0 Posted March 26, 2006 thanks alot for your help lads :wink: , as you say my best bet is to get it on VAG-com first ? just another question , Could you tell me if the SNAP-0N computer thingee will do the same job? when my first corrado vr6 had ignition probs , local garage pluged this handheld thingee into a plug under my gearstick & it gave me a choice of faults? :roll: thanks mark Quote Share this post Link to post Share on other sites
turbomagikz 0 Posted March 29, 2006 OK i couldnt wait for VAG-COM . :roll: so i got a brand new coil pack £140 , fitted it today . as i was taking old one off i spotted a MEGA CRACK ? (she smiled & walked past ) :lol: narr i had a crack right down one corner of plastic bit on coilpack. when i fitted new pack i felt possative . OHHHyessssssss my baby is like BRAND NEW now ! :shock: thank the lord . thanks for all your help lads . mark Quote Share this post Link to post Share on other sites
