Shaggy 0 Posted April 1, 2006 My ABS light on my 92 G60 has started to come on, it only ever comes on after 100mph?? its fine up until then?? could this be a problem with one of the sensors? is there a way to check them? Any help would be fantastic cheers! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 1, 2006 You need VAGCOM really - Vince will do this anyway at the RR day and be able to offer advice... Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 1, 2006 can you do vagcom on G60s? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 1, 2006 My ABS light on my 92 G60 has started to come on, it only ever comes on after 100mph?? its fine up until then?? could this be a problem with one of the sensors? is there a way to check them? Any help would be fantastic cheers! Its telling you to slow down... :lol: Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 1, 2006 i did think that actually, in theory i shouldnt be doing more than 70... 8) Quote Share this post Link to post Share on other sites
Trig 0 Posted April 1, 2006 can you do vagcom on G60s? It will report ABS fault codes on a G60 I believe... Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 1, 2006 trigger is right but you need the 2X2 adapters to hook it up. Gavin Quote Share this post Link to post Share on other sites
Shaggy 0 Posted April 1, 2006 is there any way of checking the sensors with say a multimeter? Quote Share this post Link to post Share on other sites
pkripper 0 Posted April 1, 2006 is there any way of checking the sensors with say a multimeter? Yes there is. Have a search, this is a common problem. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 1, 2006 VAG-COM works on the G60 ABS unit, but it won't remember the faults, so as soon as you turn the ignition off it's forgotten ... Have to scan it while the ABS light is actually on. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 1, 2006 VAG-COM works on the G60 ABS unit, but it won't remember the faults, so as soon as you turn the ignition off it's forgotten ... Have to scan it while the ABS light is actually on. Nope, depending on what verison if digifant you have it will alsogive engine codes as well but only accessible as blink codes and will not remember them and only if the original chip is there or the new one has this functionality ABS codes are stored in the ABS ecu and these are remembered. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 2, 2006 ABS codes are stored in the ABS ecu and these are remembered. You may be right about the engine codes, but I am pretty certain that only the VR6 had the capability to store ABS error codes, and I thought they were stored by the ECU, not the ABS controller. (Anyway, the VR6 has a completely different ABS controller setup to the G60, afaics.) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 3, 2006 It does store them (I have had to clear rear faults after being on RR sessions etc) The ECU is different as you say because the VR6 has the traction control Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 3, 2006 this is what ive had of RW1 Firstly, fault 00532 is not being caused by the disconnection of the battery. The ABS ECU is fairly dumb and just looses it’s memory faults and re-powers itself without question. Quote Share this post Link to post Share on other sites
