logicaltuning 0 Posted April 3, 2006 got a bit of a problem. need to find where my starter relay is as ive got a starting issue, and according to my mechanic (who my dad had spoken to, not me) its probably its the starter relay, only trouble is, im not sure where it is, so if anyone can point me in the right direction i would be most greatful regards ant ps, its a 92 9a Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 3, 2006 There isn't a relay - there is a starter solenoid on the motor itself The critical relays are the ones for the fuel pump and ECU. Is it cranking over? Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 nah, nothing happens at all, except when i get a wire between the stater motor and positive on the battery Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 4, 2006 It's not your ignition switch at fault is it? Check for a live feed to the solenoid when someone turns the key to the 'start' position. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 4, 2006 i was going to say ignition switch,or a damaged wire between the switch and solenoid Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 ignition switch is fine, tested it all, it was new on when i bought the car anyway, as i said, the car starts when i use a wire off the battery to the starter motor, so its either between the ignition switch or starter solenoid, and the starter solenoid is easier to check than a peice of wire in other wires, inside the car! lol Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 4, 2006 ignition switch is fine, tested it all, it was new on when i bought the car anyway, as i said, the car starts when i use a wire off the battery to the starter motor, so its either between the ignition switch or starter solenoid, and the starter solenoid is easier to check than a peice of wire in other wires, inside the car! lol So is there a live feed at the starter solenoid with the ignition in the 'start' position? If there is then the starter solenoid has had it, if not it's either the ignition switch or the connection between the switch and the solenoid. Simple as that. I don't know what sort of tests you think need to be done inside the car but it's not as complicated as you make it sound! Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 yeah, in the start position, there is a feed, i just dont fancy digging around a pile of wires to find a split in one of them is what i meant i'll give the starter solenoid a test first and see how that things doing (or not doing ) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 4, 2006 Try belting the solenoid with a long metal bar... Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 where is the solenoid situated on the starter motor, my cars under covers at home in my garage at the moment, so i cant just nip and have a look :lol: Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 4, 2006 The starter motor is the pre-engaged type so the solenoid will be a smaller cylinder on the top. It'll be obvious when you have a look. How did you test for a feed at the solenoid if you don't know where it is?! Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 thinking about it the solenoid on the motor will be working if it wasnt then putting the wire into the starter motor and onto the battery - it wouldnt start so it MUST be the wire between the ignition switch and the starter motor Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 4, 2006 have you done anything to the speaker wiring lately,mainly around the drivers side tweeter? Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 4, 2006 nah, someone had, as it fetures aftermarket components, which im in the process of removing anyway, but i hadnt got to the fronts yet, and ive had this problem since long before removing any stereo parts? worryingly though we did find 3 wires with spade connecters hanging above the fuse box, that dont attach to anything, and dont appear to have anything to attach them too. could this be one of the problems? Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 4, 2006 thinking about it the solenoid on the motor will be working if it wasnt then putting the wire into the starter motor and onto the battery - it wouldnt start ...and therefore there CAN'T be the feed to the solenoid from the ignition switch that you've repeatedly claimed there is. If there was you wouldn't need to short out the ignition switch with the direct connection to the battery. so it MUST be the wire between the ignition switch and the starter motor ...or the ignition switch. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 5, 2006 nah, someone had, as it fetures aftermarket components, which im in the process of removing anyway, but i hadnt got to the fronts yet, and ive had this problem since long before removing any stereo parts? worryingly though we did find 3 wires with spade connecters hanging above the fuse box, that dont attach to anything, and dont appear to have anything to attach them too. could this be one of the problems? if you take out the air vent and headlight switch etc,you will see awhat looks like a brass ring with connectors on it,there should be 3 wires attatched to it,yesterday i knocked off an earth wire and the car wouldnt start off the ignition switch,but i could start it from under the bonnet Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted April 5, 2006 ohhh! i'll try that cheers daz! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 5, 2006 dazzyvr6, thats interesting to know - good old VW! Quote Share this post Link to post Share on other sites
