Jstar 0 Posted April 4, 2006 Hi guys My car is a 93 2.0L. Its just about to clock 120K. and is time for its usual service. What jobs do you recommend having done on it? Especially suspension / bushes etc. I want to keep the car stock with VW parts so no need for coil overs/ lowering and all that stuff. Cheers Jay :) Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted April 4, 2006 bushes is a good idea, poss top mounts, usual coolant, oil and filter , air filter, wheel bearings? pads, disks poss? gearbox oil, oil cooler if it has been showing high oil temps lately.cam belt and tensioner if age not known. Quote Share this post Link to post Share on other sites
markp 0 Posted April 4, 2006 If you want to keep it standard then all you need to do is a standard service. If its not broken don't fix it! Quote Share this post Link to post Share on other sites
crdo16v 0 Posted April 4, 2006 Jay- personally I'd take the chance to drop in a "K & N" panel filter in the standard airbox housing & get the garage (assuming they know what they are doing) to tune it for optimum running. If you run your valver on optimax may be worth advancing the ignition a bit too. If you don't fancy doing this just get it checked out that everything is OK & put some good quality oil in with the new filter. May be worth getting the fuel filter & spark plugs replaced too. With regards to the suspension just get it checked that the bushes, alignment etc is OK. I used to have a '90 valver so assume the ignition advance etc would apply to the 2 litre. Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted April 4, 2006 If you want to keep it standard then all you need to do is a standard service. If its not broken don't fix it! Or like my mates Dad who is a retired mechanical genius. His wife has just retired and she was a primary school teacher. As she shouts Brian we hear in a mutter. I'm just of to break something on the car dear!! :lol: If its not broke...brek it hahaha Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted April 4, 2006 how do you advance the ignition timing as i always run my valver on optimax, does it make any meaningful difference? Quote Share this post Link to post Share on other sites
crdo16v 0 Posted April 4, 2006 did'nt get it done on mine but I think if you always run on optimax it may be beneficial, don't know if there are any downsides to trying it, best to read up on it first. An ace VW mechanic (if you can find one) would know. Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted April 4, 2006 not a sunday morning job then? :) Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted April 4, 2006 it should be 9 degrees BTDC anyway IIRC to suit higher octane fuel, optimax is 97 innit? Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted April 5, 2006 Whats the octane of regular unleaded? I've always used Optimax, and toyed with using Super Unleaded at Esso, as Optimax has gone upto 95p here. Quote Share this post Link to post Share on other sites
steve_16v 0 Posted April 5, 2006 how do you advance the ignition timing as i always run my valver on optimax, does it make any meaningful difference? I was always under the impression that the 2.0 ECU automatically adjusts the timing, hence you can't do the WUR mod on it. Whats the octane of regular unleaded? I've always used Optimax, and toyed with using Super Unleaded at Esso, as Optimax has gone upto 95p here. Regular unleaded is 95 octane 95p for optimax is cheap, it's about 99p round here, regular is 93p Quote Share this post Link to post Share on other sites
