Adam Darby 0 Posted April 5, 2006 right here is what happened started my corrado today and took her to work she has been under cover for a while started fine ran perfect but the oil preasure buzzer went off a couple of time. The car defo has oil pressure because its got an oil preasure gauge and the pressure stayed fine all the time. it had a new oil pump in the rebuild. vince at stealth said it will be either damp in the buzzer or a faulty oil pressure switch. Does anybody know where the oil pressure switch is so i can change it. cheers Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted April 5, 2006 the switches work by going to earth i think, so loose wires can cuse this aswell as faulty switchs. the switches are on the top of the oil filter houseing. i thing you will have a black and a white or brown one. they are cheap from gsf/ecp. :-) Quote Share this post Link to post Share on other sites
Rob_B 0 Posted April 5, 2006 if your guage says its ok dont worry about it. the pressure switches are pretty useless anyway. and 12 year old wiring wont be all that cracking after its been covered in oil and crap from your engine!! Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted April 5, 2006 its annoying. if they are to earth then i can't just disconnect them. any help??????????????? Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted April 5, 2006 i think there is a fail safe that still makes the buzzer go off if the wires are dissconnected from any senders. senders will come in at less than £10 for both from ecp/gsf. Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted April 6, 2006 and there are just the two senders on the oil cooler. what if its because of broken wires that will be a b**erd to sort Quote Share this post Link to post Share on other sites
