G60SC_Stoney
My G60 Boost reading
If I "guess" at it - Can I win the T-Shirt????????????????
I bet you have inside info.. 8)
1PSI?, 2PSI?, 3PSI?, 4PSI?, 5PSI?, 6PSI?, 7PSI?, 8PSI?, 9PSI?, 10PSI?,
11PSI?, 12PSI?, 13PSI?, 14PSI?, 15PSI?, 16PSI?, 17PSI?, 18PSI?, 19PSI?, 20PSI?,
21PSI?, 22PSI?, 23PSI?, 24PSI?, 25PSI?, 26PSI?, 27PSI?, 28PSI?, 29PSI?, 30PSI?,
31PSI?, 32PSI?, 33PSI?, 34PSI?, 35PSI?, 36PSI?, 37PSI?, 38PSI?, 39PSI?, 40PSI?,
41PSI?, 42PSI?, 43PSI?, 44PSI?, 45PSI?, 46PSI?, 47PSI?, 48PSI?, 49PSI?, 50PSI?,
You never put a limit to the guesses and I wouldnt mind a new T-shirt, I gotta be right somewhere??? :lol:
Blue_Joe, no! I've already told you...
The Hub, you STILL haven't got it right! :lol: (that leaves the door WIIIIDDDEEEE open for the correct answer! )
rallyejimbo, spot on mate!
At 6700 my G60 went normally aspirated... :shock: That is to say, it was using EVERY bit of air that the G-Lader could push into the engine with the net result that the boost pressure was ZERO... :crazyeyes:
Shows that these heads that G-man's supplying breath rather well to say the least... :notworthy:
If I want any more power outta my engine, I now have to either put on a smaller pulley, or a different type of charger which can flow more air than a G-lader! :twisted:
Thats got to be a proper work of art! Super sweet! Do i really win a t shirt? 8)
Yes email me your address . :lol:
