markievw
camshaft sensor
hi
Took my vr6 to the garage as it seems to be lacking perfomance. Came back with a problems with Camshaft Position Sensor. Will this affect the performance? and also the general running?
How easy is it to rectify? As i understand you replace the magnet.
Anybody else had this problem and how did they fix it
cheers
mark
Common problem on the VR6. Will cause poor performance if its shot (has been know to loose up to 30bhp ( think this was on kev's?)). Easy enough to replace around a 10min job. The part number for this is (W021 907 601 A) £40.73 including vat from VAG.
Yep easy to replace, it's located above the coilpack under the end plastic lead cover. 1 x 6mm allen key from what I remember.
