Waz 0 Posted April 24, 2006 hi all just wondering is some one cane help.the two pulleys at the bottom of a 1.8 16v engine the small one on the outside for the power steering pump and the bigger inside one for the alternator, well should the bigger one turn freely from the p/s pump :roll: Quote Share this post Link to post Share on other sites
bcstudent 0 Posted April 24, 2006 If you're asking whether one of the pulleys on the water pump should be an idler pulley, then 'yes'. Is that what you were asking?! The later 1.8 16v engines and all 2.0 16v engines used a two-pulley power-steering system, which did away with the idler pulley on the water pump, and drove the power-steering pump directly from the crank pulley. Quote Share this post Link to post Share on other sites
Waz 0 Posted April 24, 2006 aye sorry the water pump one so that is supposed to turn freely thanks very much bcstudent muchly appreciated Quote Share this post Link to post Share on other sites
