localhost.80
Corrado G60 idle screw missing UPDATE(Fell inside TB)
i think the correct thing to do is to:
unplug the bts (blue temp sensor,in top coolant hose) and then stick the idle screw in,turn it in untill the tickover is around the 750-800 rpm mark and then plug the bts back in.
blip the throttle a few times and check the tickover is good.around 850-900 rpm should be good.
neil. :)
if its a new one with new rubber seal on there...you will have to push it in the hole until the threads meet each other :)
unless some ones bunged sommet in there that they shouldnt have??! :shock:
without the screw in there,it should tickover pretty high,whats it like?
neil.
how can I check that? because I can only see from side angles?
0
It really sucks, 1400rpm-1600rpm on idle!
I just had some shop replace the throttle position sensor. mybe I didn't need it(ggrrr)
:bad-words:
a little mirror?
although the tickover sounds like theres probably nothing stuck in there...
try stick your finger over the hole while the cars running :)
neil.
I checked the idle screw using a mirror like you said , :D and to my surprise I found the screw suck all the way in. :shock: Now what should I do?
Turn on the engine, warm it up to around 80degrees water and oil temps, disconnect the blue temp sensor and then unscrew the screw until you get a decent idle speed... reconnect the blue temp sensor and you should then have a good idle speed from then on... ;) 8)
