mbaker8v 0 Posted May 4, 2006 Guys, Since u put the Corrado back on the road it is making a nasty metallic rubbing / clonking sound. Sounds a bit like two pieces of metal brushing past each other.. always happens twice as though it moves away then back to its original position. It happens usually when you take up the power as you pull away, thought it was the clutch at first but doesnt do it if your very very careful and pull away gently. Also get the sound when going over some bumps, seems to be worse when pulling away on a junction i.e. pulling away and turning. Im pretty sure its coming from the front as you can also feel it through the floor. Any ideas before i let my local VW specialist have a look / listen. Cheers, Mark Quote Share this post Link to post Share on other sites
