dannyc
poor idle spped
Evening all
My bro's C is running abit ruff at idle, but is fine once you get going. he has been told that there is probably a hole in the inlet pipe
what do you guys think it could be?
cheers :)
have you cleaned the isv? also check for air leaks as the kejet system is very sensitive to leaks.
edit what idle speed do you get?
I'd be looking at the ISV first, followed by the connections to the ISV, follwed by the closed throttle switch on the throttle body.
