MarkGolf 0 Posted May 7, 2006 Hi, I've got a 13 row cooler and that is all.. I know I need a sandwich plate and hoses. I plan to pop down to think automotive this week and get myself these bits, but, is there anything else I need? What is the thing in the bag and can I bin the standard oil cooler? I have no clue when it comes to the best set up for oil coolers so any advice is good advice! Thanks p.s, what length hose do I need? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted May 7, 2006 i can supply you these parts all you need to is specify the length of hose needed and also what thread type on your cooler. Std is 1/2"bsp for referance Quote Share this post Link to post Share on other sites
MarkGolf 0 Posted May 7, 2006 Not 100% sure on length as yet.. (Whats everyone else had?) Can I bin the standard oil cooler? I'll be inclined to go with you :D goin le man ths year? Quote Share this post Link to post Share on other sites
fla 9 Posted May 8, 2006 MarkGolf, I'm in th esame position as you my man. I've got just the cooler and nothing else. I'd be interested in your comments g-man, Oh, and mines a VR with aircon so i'm a bit rtestricted on space. Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 8, 2006 I have a mocal cooler. 1/2" BSP fitting with 1 m of line all hooked up to a Mk1 Oilfilter mount. 1.5m of line should be fine. My cooler is mounted infront of the Rad. I dumped the original oil water heat exchange unit. Still got it in the shed. Will refit if it is needed. Quote Share this post Link to post Share on other sites
ReekieVR 0 Posted May 8, 2006 Is the oil cooler the same as the corrado vr one ? Quote Share this post Link to post Share on other sites
fla 9 Posted May 10, 2006 2_Door_fun, do you have the sandwich plate and thermostat setup or is the mocal permanantly in circuit regardless of oil temp? Quote Share this post Link to post Share on other sites
Tristan 0 Posted May 14, 2006 Is there a part number for a thermostatic sandwich plate oil cooler? Quote Share this post Link to post Share on other sites
