VR6 Russ 0 Posted May 10, 2006 Right started a new thread because I don't know how to edit my old one. :oops: These ventura springs are c**p the spring has completely removed itself from the top mount after driving if for less than 5 miles and my mechanic has advised me to go with a different make. I have decided on H&R and need to know the best place to get them from ASAP. Share this post Link to post Share on other sites
Taggart 0 Posted May 10, 2006 I got my coilies from europerformance, came within a day or two, you need to find somewhere that has them in stock, ring around. Share this post Link to post Share on other sites
VR6 Russ 0 Posted May 10, 2006 Just after the springs mate. Anywhere else I can try so I can compare prices, but I need to order them ASAP as my car will be off the road. :mad: Share this post Link to post Share on other sites
andy 0 Posted May 10, 2006 Are you sure you've got the right top plate on the spring, there are two types and one of them will not sit right and will come off. I've changed two sets of springs, one on a Golf VR6 and one on my current C VR6 and had to change the top plates on both occasions. Share this post Link to post Share on other sites
Walesy 0 Posted May 10, 2006 Hi VR6 Russ. To edit a post, click on the 'edit' button on the top right of the post. Or just post another question in your original thread if that's easier mate :) The reason us 'hitlers' try and keep everything in one thread is that it gets confusing if there is seperate threads about the same subject :) http://the-corrado.net/.archive/forum/viewtopic.php?t=41545 Share this post Link to post Share on other sites
