JIMMI 0 Posted May 13, 2006 Hi guys What sort of temperature does your VR's run at in normal driving. I have just repaired mine and got it on the road and it runs fine but the fan kicks in after a few minutes in trafic when the temp gauge is reading 100 deg C. the fan cuts in for a few seconds then goes off when the temp of the motor drops so it isnt getting all that hot. the oil temp on the maf has never rose over 68 so i think the water temp sensor may be reading a little high. What do you think ????????????? Also i need a new centre exhaust box, and i dont want a boy racer Magnex or similar just a standard one is there any alternative to a new vw one. Cheers jimmi..................... Share this post Link to post Share on other sites
VR6 0 Posted May 13, 2006 Could you use the search for this one please? :) It's been discussed a lot! Try searching for: VR6 AND oil AND temp* or VR6 AND running AND temp* Try narrowing search to Engine Bay or General forums as well. There's also a lot of exhaust discussion in a Stick thread so that should already have been well-covered. Ta etc Share this post Link to post Share on other sites
