G6T-RIZ
installing coilovers
just got my coilovers on and the car sits quite low.took it for a drive and it feels totally strange.the car wants to go in every direction.it feels like your driving on ice.ive not got the wheel alignment done yet.will this solve the problem.also when the car is lowered down from the ramp the to of the strut seems to come up alot, is this rite or have i mised out sumthing when installing them.
The alignment is likely to be all over the shop at the moment which won't be helping, plus depending on how much you've lowered it at each end the castor and camber won't be helping.
Get is measured and find out how far it is from standard then decide on the ride height and get the cmaber adjusted to suit.
Are you sure you've tighten'd up all the top mounts... This woul cause it to go all over the place!!!
Are you measuring each side correctly??? Ones not higher than the other...
