mirroredone 0 Posted May 20, 2006 hello people , can anyone help, i'm trying to do the rear brakes on my corrado, but i've got a problem, i cant remove the carrier, because i cant work out if its pozi drive or allen key, if any one can help it would be brilliant as my car is in bits at the moment needing to go back together. cheers Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 20, 2006 Calipers on my 60. Caliper bolts were standard bolts. Caliper bracket attaching to hub was Allen bolts. Use a blow torch on the Allen bolts. They unwind very eay. The heat expands the threads and it just breaks the rust spin out easy. Quote Share this post Link to post Share on other sites
flusted 0 Posted May 20, 2006 should be 8mm allen key i think? Quote Share this post Link to post Share on other sites
Phil K 0 Posted May 20, 2006 If you're just doing the pads then the caliper can stay in situ... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 20, 2006 Rear caliper carriers on a C are attached with Allen head bolts (with a fine thread) Quote Share this post Link to post Share on other sites
mirroredone 0 Posted May 20, 2006 nice one you have just made my day, it has finally worked,( laugh you may) after 4 hours trying. thank you very much Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 20, 2006 No woories - glad you got it sorted! Quote Share this post Link to post Share on other sites
