andyVR6
Do all VR6's come with oil coolers as standard.
all i can see on mine is a cooling pipe for the power steering fluid. if they have got em where do they hide them.
There is a pipe for the power steering that runs around the front of the crossmember its supposed to be a cooler for PAS.
Take off your front bumper,its the easiest way to check if the pipe is corroded away or hose clips are loose
Yep. Audis have the same thing but they go one step furter and mount it infront of the radiator in a kettle element shape.
