nigwell
Engine Turns Over But???
Hi
Ive got a slight problem with my VR6 it turns over but will not fire up? it does occasionaly fire up but very rarely, :roll: does anyone have an idea???? as its driving me mad :mad: ive had the fuel filter replaced and the fault codes checked.
cheers
nigwell
mine was doing the same ended up being the distributor it was totally dead managed to get replacement off ebay for 25 quid though
hi dazzy
yes there is fuel coming through? and i have a coilpack instead of the distributor? to be honest though i havent checked to see if there a spark.
nigwell
sounds like the factory-fit immobiliser playing up.........in that its not reading the code from the "transponder" in the key or vice~versa
if you try a search on the forum you should be able to find out more.......if not do a search on the yahoo-e-group :wink:
ive had the alarm checked out already thinking it was the immobilser, i think the car was pre transponder aswell 1993?? i think thats the year of change
nigwell
I think Roddy has hit the nail on the head.
Kev
found this on the yahoo-E-group:-
Date: Tue Aug 13, 2002 7:19 am
Subject: RE: [Corrado-UK] VR6 cutting out problem part 2
A common fault with VR6 C's
Unfortunately can be any number of things but the most common are:
1 Faulty or dirty MAS sensor (Air Flow Meter) - Try removing the sensor and
cleaning with some carb cleaner. Check the readings on the sensor as
detailed in the Bentley manual.
2 Faulty ISV (Idle Stabilisation Valve) - Again remove / clean or swap with
another C owner to see if the problem goes.
3 Factory Immobiliser coil has slipped and is causing the engine to cut out,
Only fitted on cars late '94 - to end of production run. Check to see if you
have a transponder key, if so remove the plastic surround from the ignition
barrel and ensure the receiver (metal coil) is firmly tied in place adjacent
to the lock.
4 Faulty Ignition switch.
Hope these give you some more pointers to look at.
Regards,
Guy
-----Original Message-----
Sent: 12 August 2002 19:46
To: mailto:[email protected]
Subject: [Corrado-UK] VR6 cutting out problem part 2
Hi there,
I posted the following message a few days ago. Since the posting the
car has been down with the VW specialist. They have checked the
majority of your suggestions and I wanna thank you all heaps.
The problem is still there and the last time I drove the car it cut
out 8 times in 3 miles. I have also noticed that it does not seem to
cut out from cold for the first mile or so but does very frequently
from then on. I have had this problem for a few months (very
infrequently at first) but it has got gradually worse. But when I got
the Toad immobilizer removed it appeared to stop for awhile. In the
meantime I drove upto and around Scotland 1800 miles with no
problems. Then shortly after getting back to London the problems
started again, getting worse and worse.
The garage who are looking at the problem have say that both fuel and
ignition are stopped when the problem occurs. I beleive they have
also tried changing fuel pump and relay etc but with no luck.
If anyone has any more suggestions it would be greatly appreciated.
Many Thanks
Kevin
Original post
I have a Corrado VR6 which I love. However I have been having
problems with it and no-one seeems able to diagnose them.
The problem is that when driving along the car will suddenly cut out
and will not re-start for a few minutes. When it does restart it runs
perfectly until it cuts out again. The problem has happened when both
hot and cold and at all speeds. It has also got much more frequent
recently. Yesterday it cut out 3 times in 2 miles.
Your help would be very greatly appreciated. Auto electricains and
garages seem to be baffled by this but I am sure someone out there
has had the same problem.
Many Thanks
hopefully this might point you in the right direction :wink:
