Linus Van Pelt 0 Posted June 19, 2006 Info and advice req'd :wink: (9A Engine) The induction hose thing running from the top the the airbox to the throttle on the top of the engine is split into several different pieces, interconnected with jubilee clips. The section which is closest to the engine itself has a small plastic tab (?) on the underside which then connects to two thin hoses (?). This tab became detached and jammed the throttle valve on wide open :cry: Anyway, long story short, the nice man from the AA said I should get this part changed. For the moment the offending tab has been superglued in place. Can anyone throw me a part number and or advise me whether this is dealer only etc? Having seen the repair man take it off and refit, I think even I could manage this one lol As an aside, has anyone encountered something similar or knows how this tab thing is supposed to be connected to the hose in the first place? Thanks in advance for any help and apologies for the vagueness in my descriptions :oops: Quote Share this post Link to post Share on other sites
-Neil- 0 Posted June 19, 2006 I had a problem with this piece your on about... i replaced the whole thing, i got it for like £5 from someone off here. look at this thred, it shows you where the two pipes go.. http://the-corrado.net/.archive/forum/viewtopic. ... ht=#397087 Quote Share this post Link to post Share on other sites
Linus Van Pelt 0 Posted June 19, 2006 I had a problem with this piece your on about... i replaced the whole thing, i got it for like £5 from someone off here. look at this thred, it shows you where the two pipes go.. http://the-corrado.net/.archive/forum/viewtopic. ... ht=#397087 Much appreciated, thanks for your reply :) Quote Share this post Link to post Share on other sites
-Neil- 0 Posted June 19, 2006 no problem, glad to help. Quote Share this post Link to post Share on other sites
