Goldie
VR6 Running Parameters
Can anyone advise me as to what their running oil temp is for a standard VR6 and the temperature that the cooling fan should kick in please??
Little concerned mines getting a little hot under the collar and prevention is better than cure.
Cheers fellas.
Mine doesn't go that high but it might depend on how the car has been driven.
Does the temp go back down once the fans come in ?
Have a look in the VR6 Running hot thread further down in this forum for more in info on what might be wrong, or not.
If the fan is kicking in at 110 is that over the top??
If it's getting that hot at idle and the fan isn't coming on then one stage of the fan switch has gone but the VR is a bit different in that it has 3 stages rather than 2...
Once the fan has ran at 110, it will cool itself back down to about 100 to 105. Is there a way to check the stages of fans running??
Grateful for the advice.
But thankfully I don't look like you :-) Nice hat! 8)
I'm very surprised that no one has mentioned the hat (or the PINK sunglasses yet) tbh :(
I've decided a rotating gallery is the key to a happy avatar
