PhilSatch
G60 Engine Cuts Out
Wonder if anyone can help...
my G60 cuts out once it has warmed up, it then turns over but will not start. If I leave it to cool down for a bit it starts but then a few minutes later it'll cut out again.
I've tested for a spark when the engine is turned over after cutting out and there isn't one.
I've been advised its probably the ECU or dizzy....
Has anyone had this problem with a G60 before? any ideas?
Thanks very much.
I had the same problem once, like Supercharged said, it was the hall sender, they're pretty notorious for it i think.
Having same problem with my g60.fuels pumping ,but theres no spark.Thought it might be crappy imobilizer fitted.how much are hall senders.cheers
Nice one Phil - you may have found the new one is a different colour / number and made in germany (if the old one wasn't then I reckon you have found the problem as they are known to fail...
covincharger, hall sender is part of the dizzy which is about £100 exchange from VW.
