popper
electric seats, help please!
hi, im a newbie to corrados, just bought a vr6 with recaro electric seats. the problem ive got is that the drivers seat only adjusts leaning forward and not back, so ive now got it stuck in a very uncomfortable driving position. Anyone know how to fix this or somehow just manually adjust it? dont really want to pay a dealer silly money to fix it. any help appreciated.
Sorry .. just realised ive posted this in the wrong section.
Hi mate, welcome to the forum.
I had this problem with Electric Recaros , it was easily solved by removing the switch and giving it a douse in contact cleaner.
If in the worst case the switch is broken, I think they're around £40 from VW
Thanks for the advice mate. Take it you unscrew the plastic cover thingy under the seat to get to the switch?
I had the seat out when I removed the switch, from memory there were clips on the inside that you need to press in?
So do i need to remove the seat to get to the clips? Also soz if im a bit thick but where can i get some contacts cleaner from? thanks again.
