bensurf
MFA Help!
I need to check the oil pressure of my C, ive read somewhere that you can change the function of the mfa by doing this...
Start Motor
Move the MFA selector to "2"
Press and hold the MFA end button (keep holding)
Stop motor
Start Motor
Release the MFA end button.
Press the MFA End button one time.
and i was wondering if the oil pressure is one of the new functions, also do you know the correct pressure of a 2.0 16v?
Thanks
That’s for reading MFA live data such as road speed, engine vacuum/boost, distance etc. The Corrado has no dynamic oil pressure sender apart from two switches, one for 0.3 bar (pressure to open) and one for 1.8 bar (pressure to close). There is wiring for a dynamic pressure sender but it is a rare option. I have a Corrado VR6 auto in at the moment with the OE option volts/oil press instruments in the centre consul.
