nsawyers
Corrado G60 Irractic Idle
I have had trouble with high idle with my car since I brought it. The idle screw is all the way in and it sits at 1200 rpm sometimes it drops to 850. I have recently rebuilt the head and changed all thr gaskets hoping to rectify the problem but it is still doing it. The blue sensor has been changed. I was thinking may be the ISV is at fault. Any ideas? plse :mad:
you can take the ISV off and clean in in carb cleaner, this seems to solve most peoples problems, didnt solve mine though! mine was fixed when i took it down to gwerks to have a few things done to it. you can also just disconnect it (plug on the left side) and that will stop it, just runs a bit lumpy when started from cold for a minute.
I will try unplugging it and see what happens.. if does drop down the revs I will clean it.. trial and error.. :-)
check the wiring to the idle switch and make sure that the switch is being activated when the throttle pedal isn't pressed. Sounds to me like a dodgy switch problem as the car should idle around 850 RPM and will idle around 1200 to 1500rpm when the switch is disconnected which fits your symptoms nicely... ;)
