elrikos
fuel pump running on
this may well be connected to the getting very hot scenario in the other post but as it may be a seperate problem i've posted 2 topics (please feel free to merge them etc mods).
When i stop the car after a bit of a drive (when it gets hot (100-110 degrees running temp). i lock the car as normal (using the alarm blipper).
After a few minutes the fuel pump seems to reactivate itself and you can hear fuel being pumped up to the front of the car and then hear it running back to the tank.
Is this right????? Is it to possibly cool the injectors or some other crazy reason?
Cheers
RIch
Yes, that is normal in all Corrados!
So don´t worry.
It´s called the after-run system i think... :)
