1st rado for me
Changing Brake Fluid
Hi Guys
I want to change my brake fluid tomorrow, I have brought some nice new fluid and a eezibleed kit.
Where do I start??
What is the best way to drain the fluid??
What is the best way to bleed the system??
Also is there any meets or relevant clubs in the Bristol area??
Cheers
There's loads of info if you search mate, but basically start at the furthest wheel ie rear n/s and work towards the nearest wheel to the master cylinder, you may need to bleed the master cylinder too. I did my clutch whilst I was at it as well. Don't drain the fluid as such, just use the new fluid to push the old out.
