A5 VRX
VAG-COM
Right ABS light is permanently on (this isnt another ABS Q), local garage tried to read the fault on there computer to no avail, decided to go to the local VW specialist and put it on there VAGCOM, again nothing. Replaced a dodgy sensor and tried them all with a multimeter and all looks good. Only thing is the light is still on and only VAGCOM can switch it off, mot is friday and the geezer has already spotted the fault, really need to sort it V quick. is it worth hooking up to the dealers computer?
if the light is still on, there's still a fault.
VAG-com won't turn the light off, the ABS system will do that on start up when it recognises there's no faults.
Hooking it up to the dealers computer will tell you why the light is on, but won't fix it.
