BeavisJem 0 Posted July 13, 2006 Don;t really know how to explain this. Occasionally i get a low down sound, like marbles ratterling around, coming from the engine when i floor it in 2nd or 3rd low down in the rev range, the revs don't need to be high. If i floor it at 2k i can somtimes hear this marbles roling around sound? :( Sometimes its not there at all. Engine is a 1991 G60 with 126000 on the clock. Don;t think its pinking. Always use good fuel, serviced etc. Anyone offer any insight Cheers Quote Share this post Link to post Share on other sites
dr_mat 0 Posted July 13, 2006 Might it be the cat heatshield rattling? Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2006 sounds like bottom end bearings to me from that description... :| Quote Share this post Link to post Share on other sites
DUB 0 Posted July 13, 2006 Might it be the cat heatshield rattling? I've had this and some times still do - you should get it up on a ramp - I found with mine it comes from exhaust&heat shields vibrating - turn the radio up or go faster - nothing to really worry about mate Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2006 if it's the cat heatshield, simply put a LARGE jubilee clip around it, and it won't rattle anymore.... ;) Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted July 13, 2006 Bottom end bearings don't sound too good, i know its not the cat heatsheild as i had that welded a couple of months ago. Errrrr so bottom end bearings how can i test......... "where's my wallet" It just sounds a bit ratterly when its floored at low revs, it might be there at high revs but the exhaust might be a bit loud to hear it :oops: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted July 13, 2006 Cat heat shield might have come loose again .. unless you know that sound, and this is not the same .. ? Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted July 13, 2006 no its not the same sound :( Quote Share this post Link to post Share on other sites
peteTDI 0 Posted July 13, 2006 my car making/doing the some, need to whip the sump off and see what busted, good time for a few upgrades :roll: , like my exhaust that fell off today :oops: good luck lets hope your luck is better then mine Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted July 13, 2006 Put the sharp end of a screw driver on the rocker cover, and the handle on your ear, sounds strange, but if it is the bottom end you'll hear and feel the vibrations through the handle. Thats what mine did. Also, the engine is at its most unstable at 2200 revs ish, so see if thats where you can hear it the most. Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted July 14, 2006 Cool cheers will let you guys know :) Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 14, 2006 My VR has developed a strange whistling noise today - any ideas? Only heard it when it was ticking over and was outside of the car! Quote Share this post Link to post Share on other sites
