iow_corrado_g60
Shrick Oil Sump
The design of the schrick sump allows it so sit squarer to the road (if that makes sense) as it has a flat bottom to it. These are 6mm thick on the bottom which is alot thicker than most sump guards so there shouldn't be any problems (you could quite happily jack your car up from one of these (although not recomended)
billinjah, you doing bloody well to touch your sump on the road there mate as even when Furks Car goes down to our preset *show* height the sump never comes close to the road. It may be worth checking your front mount to make sure the engine isn't sitting at the wrong angle.
billinjah, if your sump's hitting the floor, be bloody careful as they've been known to flatten out slightly, block the oil pickup and starve the engine of oil causing it to seize up solid... :crazyeyes:
I was a bit worried about using an alloy sump until I saw a shrick one in the flesh and realised just how much flesh there is to them! :lol:
