Bohall
Leaking Brake Master cylinder!
Noticed a small puddle under the car last night to my horror, had a look and noticed the 2 seals where the resevoir sits into the brake master cylinder are leaking. Just wondering is there a seal kit available or do i have to replace the master cylinder?
It's not leaking badly but it's still enough to make me concerned.
Cheers.
357 611 817 at £2.36 each inc. VAT. Be careful not to let lose flakes of rust into the mater cylinder when swapping them, it is the rust that causes the problem.
No bother, thanks for that.
It hasn't lost any fluid since i topped it up last night so it should be ok to drive gingerly. Since the clutch uses the same resevoir i was getting a bit worried after RMN pointed it out to me!
