Ronan 0 Posted July 20, 2006 Basically, how hard is it to adapt an late exhaust to fit an early Corrado - is it worth the hassle on a second hand system, or is it a straightforward job? Thanks! Quote Share this post Link to post Share on other sites
g60griff 0 Posted July 21, 2006 i dont know about this but i need to know aswell. Quote Share this post Link to post Share on other sites
Henny 0 Posted July 23, 2006 it's easier to convert the car not the system as the hangers on the car just bolt on, where the ones on the exhaust are welded... ;) Your problem is probably going to be getting hold of the hangers you need... ;) Quote Share this post Link to post Share on other sites
peteTDI 0 Posted July 23, 2006 you may find one middle part is longer aswell, my old exhaust before if fell off had the bar in the middle when the car had two hooks and some string holding it on (right lash up), the middle box had been cut and rewelded to make it shorter aswell if this helps Quote Share this post Link to post Share on other sites
