Baz2004 0 Posted July 24, 2006 Can anyone help me with the part no on this oil sensor? It’s an early 16V KR 1.8 engine, cant get a part no/details on my version of etka. Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 24, 2006 Can anyone help me with the part no on this oil sensor? It’s an early 16V KR 1.8 engine, cant get a part no/details on my version of etka. the part number is on it! to be fair it's difficult to see, underneath and needs cleaning to read often, but it's a standard black top oil pressure sender (not temp), if you need one I've got a couple from my KR sat in a tub in the garage. David. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted July 24, 2006 Its tricky to see it with everything back together, I didn’t want to go taking it off to find the part no cus its working Ok I think its weeping a bit of oil so I want to replace it. Id rather have the part no going into GSF/VW cus I’ve been given the wrong switches in the past without part nos. Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 24, 2006 Its tricky to see it with everything back together, I didn’t want to go taking it off to find the part no cus its working Ok I think its weeping a bit of oil so I want to replace it. Id rather have the part no going into GSF/VW cus I’ve been given the wrong switches in the past without part nos. should be 068919081 oil pressure switch 1.4bar 1 pin black if it's leaking from it's washer nip it up a bit more, if it's leaking from the top replace it before it pisses oil out :) GSF: 93447 OIL PRES SWITCH VW/AUDI PETROL ENGS 98> 1 PIN BLACK(1.2>1.6 BAR) 4.50 Quote Share this post Link to post Share on other sites
Baz2004 0 Posted July 24, 2006 Cheers mate I reckon its leaking from the top. Quote Share this post Link to post Share on other sites
zacon 0 Posted July 24, 2006 That is the high oil pressure switch. The black type which triggers at 1,4 bar has part no. 068 919 081. The gasket ring is part no. N 013 811 5, according to ETKA. Quote Share this post Link to post Share on other sites
