Goldie 2 Posted August 14, 2006 Im having a nightmere with the car at the moment, firstly ive sprung a difficult to find coolant leak and this morning i took the car out and it felt terrible. It feels like a misfire and when i lifted the bonnet i can hear a clicking sound. I thought that the car must be cold and a bit damp after 24 hrs of rain but this has continued once its warmed up. Does anyone have any ideas?? Hoping its gonna be a leads and plugs job. I could also do with a recommendation of a garage to sort my leak, am in Durham but spend most of my time down south so dont really know any garages in the North East. Advice greatly appreciated. Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 14, 2006 My car was misfiring ended up being a dirty MAF, idk, you could try cleaning it with MAF cleaner, NOT WATER OR TISSUE Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted August 14, 2006 Ended up being the coilpack on mine, no obvious cracking. Had a mate with a VR6 Golf and swapped it to double check before buying a replacement from GSF. This was after changing leads, lambda and plugs with no effect. Quote Share this post Link to post Share on other sites
Guest Posted August 14, 2006 depends. misfiring with a coolant leak could be the head gasket (worst case). could be the coilpack, HT leads, MAF, lambda, etc etc. best bet is to find someone local and try switching things peeps used to test the coilpack with a water atomiser in the dark. Quote Share this post Link to post Share on other sites
biggrim 0 Posted August 14, 2006 Check the ECU relay fuse. Could have a dry joint or not be plugged in properly. Not sure where it is on the VR but on the G60 it's the top row, third from the left. Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 14, 2006 Thanks for the pointers fellas. Started the car again later today and it ran fine however the clicking/cracking is still hapenning. Checked the history file for the car and the leads are ancient so think im gonna bin them as a matter of course and see how i get on from there. Ill check out the other suggestions, get the leak fixed and fingers crossed for happy motoring agin. Thanks again. Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 14, 2006 easiest thing to do is clean the MAF before you go buy stuff, get some MAF cleaner, just a suggestion who knows it might just be dirty GL Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 14, 2006 What sort of cleaner should i be looking to get CorradoDriver, ?? Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 15, 2006 Something thats says MAF cleaner and make sure what ever you get it says sensor safe on the back, idk about in the UK but here in the US i used CRC Mass Airflow Cleaner, pull out the MAF and spray it on the inside on the sensors, let it dry for about 10 min, the spray dries pretty fast but to be on the safe side let it sit, while you have that out might aswell get intake cleaner and clean ur intake. Put it back together, and hopfully ur problem is solved GL Quote Share this post Link to post Share on other sites
