StuartFZR400 0 Posted August 16, 2006 As said above, seems there is a small oil leak from the top of the oil filter housing where a cable goes in. Presume it is some kind of sensor. :?: - is this normal to go? - will it just be a seal? - or more likely the sensor perrished? a - is it safe to undo (looks to be 23mm) ??? b - or should all the oil be dropped out first? any tips would be great! Id refer to the naffy manual i have, but stuff like that it just says "remove filter, remove sensor, put back together, simple!" Quote Share this post Link to post Share on other sites
KADVR6 0 Posted August 16, 2006 had this when doing my supercharger, just take sensor out 23/24mm. and put some PTFE tape on the thread, tighten up, and job's a good un. Quote Share this post Link to post Share on other sites
Deluk 0 Posted August 16, 2006 yeah pull of the rubber if it leaking from the spade clip change the sensor Quote Share this post Link to post Share on other sites
