Kick Up The Rs 0 Posted August 23, 2006 Mine feels a bit week, so it's time to change it. How big a job is it? Any pointers much appreciated Ta Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 23, 2006 Its straight forward to do,why do you think that mount is weak? Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 23, 2006 My local indie gave the car a once over about 5 months ago and he said it was looking weak. And very recently, I'm feeling the engine 'move' when I take up drive. Also had new front mount, top mounts and wishbone bushes very recently - so it aint any of those (i hope). Where is the best place to take the weight of the engine? Quote Share this post Link to post Share on other sites
Riley 0 Posted August 23, 2006 block of wood under the box i reckon? carefully placed obviously 8) Neil. Quote Share this post Link to post Share on other sites
Shaggy 0 Posted August 24, 2006 the last time i tried to change the rear engine the one i got from GSF didnt even fit properlly!! its not a bad job, just make sure the mount you get is VAG Quote Share this post Link to post Share on other sites
robster 0 Posted March 23, 2007 Will be doing mine soon on my G60, I have read somplace that you need to drop the subframe !! is this ture, had a quick look and it is very tight in there, Whats best way of changing step by step would really be apprecited, will be using a lift to do job. Rob. Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 23, 2007 Will be doing mine soon on my G60, I have read somplace that you need to drop the subframe !! is this ture, had a quick look and it is very tight in there, Whats best way of changing step by step would really be apprecited, will be using a lift to do job. Rob. all you need on the 4 cyl cars is to lift the engine a cm or so to slide the old mount out, you may need to lift the car slightly if it on lowered suspension as the wishbone on the drivers side gets in the way a bit do not buy GSF unless you use the car on the track, the vibration will knock your fillings out, AVS 'FEBI' ones are fine though here Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted March 24, 2007 Yes, I have fitted 2 now. The GSF was a pile of sh*te as it was tooth shatteringly stiff. As for lifting, I used a trolley jack on a couple of bricks and lifted the engine on the block lip at the front. The mount will come out - after a bit of wiggling and manipulation... Dead easy. Quote Share this post Link to post Share on other sites
