big_chris1981
knock sensor questions....
one of my knock sensors is giving a ground to earth error on vagcom....so its fair to assume its dead.
can someone post up pictures of what they are, and where they are?
would it be fair to assume that if one is dead, then then engine is running rich and thinning the oil out....hence the high oil temps?
does anyone have some known working ones for sale in the southampton area??
cheers
chris
it doesnt seem to be doing it....theres no run on, no pinking, performace appears to be good.....was only that vagcom picked up the fault.
can someone take me some pictures of what im looking for on the engine?
i know that one is at the front....
The only downside with broken knock sensors is the engine will run with the ignition fully retarded, so performance will be down slightly. You shouldn't notice pinking or anything untoward.
