flusted 0 Posted September 5, 2006 Ive decided to ditch my intercooler sprayer and use the bits for water injection. The pump im using is really powerfull and blow the joins off on washer jet hose :oops: I have a boost activated switch,so all i need is a weld in bung and a nozzle. Can someone give me an idea of what size jet il need? Hoping to be running over 200bhp with current spec so need the jet to suit Any ideas? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted September 5, 2006 Oooooooooooooooooooooo I'd be really careful with this!!! What pump have you got and exactly how powerful is powerful. It's a little more complicated than this i think really! I've got the Aquamist 2d system and personally with something like this I would only ever get a tried and tested system as get it wrong and you risk Hydrolocking the engine! In order to pump the water through the jet to create the fine mist required the aquamist pump runs at 300cc/min @ 6bar Quote Share this post Link to post Share on other sites
flusted 0 Posted September 5, 2006 But people get away with using windscreen washer pumps :roll: I understand about the hydrolocking but it would take a hell of a lot of water to do that? Its not as powerfull as a "proper" 1 but is there a way i can measure it? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted September 5, 2006 You definatly CAN'T use a washer pump for water injection. And no it's not really that hard to hydrolock an engine. Can't really offer much more advise than really recommend that if your going to do it, use a proper setup to be on the safe side. Is your engine worth risking???? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted September 5, 2006 how much is an aquamist system! Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted September 5, 2006 A 2d system is about £500 IIRC plus I got the in dash display which is another £150 Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted September 5, 2006 thanks sam Quote Share this post Link to post Share on other sites
