Riley
Quick G60 compression test question...
Alright guys,what are respectable figures for a dry test on a standard pg G60?
150 psi alright on a mates? pretty sure it is? although mines up at 170psi :?
Oh,and on n0.4 of a mates motor...the compression would jump up to 100psi and than couple of turns more and it'd bump up to 150psi.
Sound like a sticky tappet/valve?
Cheers,Neil.
150 PSI = 12 BAR
Sounds a lot for a G60!
Is your engine modded?
I assume you did the test taking only one spark plug out at each time, right?
Yep,did a dry test on one cylinder at a time,full throttle.
so 150psi is a lot? thought it was about right? :? mines actually at 170psi :shock:
Neil.
