colinstubbs 0 Posted September 14, 2006 On the last Surrey rolling road bash my 1.8 16v only developed 133.1 BHPand I was told that it was over fuelling high up the rev range. What would cause this? Faulty fuel pressure regulator? My only mods are washable filter, drilled airbox, Milltek exhaust and I've got a weber fire breather TB fitted. This is s'posed to be good for another 15-20 BHP but will tend to lean out the valver as i understand it, so what the hell's happened there then?? Any thoughts gladly appreciated!! Quote Share this post Link to post Share on other sites
mistrall 0 Posted September 15, 2006 i got 132 Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 15, 2006 On the last Surrey rolling road bash my 1.8 16v only developed 133.1 BHPand I was told that it was over fuelling high up the rev range. What would cause this? Faulty fuel pressure regulator? My only mods are washable filter, drilled airbox, Milltek exhaust and I've got a weber fire breather TB fitted. This is s'posed to be good for another 15-20 BHP but will tend to lean out the valver as i understand it, so what the hell's happened there then?? Any thoughts gladly appreciated!! wierd, 16v's usually lean out at the top end, do you have a power/torque plot? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted September 15, 2006 i got 132 Yeah we really let the side down with our Valvers!! I got the plots here (hopefully- first time for everything!) Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted September 18, 2006 Bump :confused4: Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 19, 2006 Bump :confused4: Have you had the CO set since you did the airbox filter and throttle?, the graphs look as you would expect for KR cams torque and power, there's always a mid range dip and then things climb strongly to about 6500rpm, although yours might tail off a bit early, but then I guess it's not a new engine. It may be that your best bet is to book it in for a couple of hours on the rollers with someone who can diagnose and set up K-jet properly, e.g. Stealth. David. Quote Share this post Link to post Share on other sites
