lamwagon
mk4 brakes! need thicker discs
just fitted them on the rear but i used the v5 ones which i belive use vented discs, anyway i have them on and working fine at the mo but because iam using thin solid brembo discs the pistions are at full streach all the time so was wondering wot thicker discs i can fit?
cheers Adam
I didn't know the rear vented 256 calipers would fit on the carriers?! Well, if they do, then they're the discs you need. 256s.....but they won't fit on the stub axles without major modifications down there.
there solid brembo discs for the g60 not sure how thick ill hav to check,
there pagid pads again hav to check which size they are.
i fort i was given the wrong calipers lol
so is there no thicker discs i can fit then.
cheers Adam
