willg95vr6 0 Posted September 23, 2006 Can any one tell me whare abouts it is located, i have a 95 vr6. is it one of the ones behind the glove box if so which one is it. many thanks Will Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 23, 2006 Bottom right... 80 If it''s not made in germany then get a new one! Quote Share this post Link to post Share on other sites
willg95vr6 0 Posted September 23, 2006 cool i got a new one and its made in germany - thanks for that Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 24, 2006 which one is the fuse relay on the 94 vr6. Fuse box is on drivers side, and the fuse numbers seem different also? Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted September 24, 2006 Its located at the bottom right of the board, relay 167. Quote Share this post Link to post Share on other sites
willg95vr6 0 Posted September 24, 2006 i have just noticed the fuse relay is still the bottom right as supercharged said but its is a different number. you can tell if you take it out you will find it had the same pin lay out. it is the only one that fit Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 24, 2006 thanks for that. Mines made in Portugal as oppose to Germany - what difference would this make..im guessing that it would mean that mine is not a genuine VW part? does it really matter?? Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 24, 2006 I have just found that one of the metal connectors on the fuel relay 167 is loose( compared with the others) - could this be the culprit for the hesitation across the rev range most of the time? How much is a new one of these? worth changing the ECu at the same time. Whats the correct number for ECU also. So many questions...sorry! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 25, 2006 Yeah change them both, the Portugal will be genuine but they had some quality issues... on a VR I think both relays come to about £30 Quote Share this post Link to post Share on other sites
fla 9 Posted September 25, 2006 ECU relay is number 109 Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 25, 2006 Thanks guys, I will get a couple of new ones and see whether I notice any difference. Quote Share this post Link to post Share on other sites
