tallpaul1977
Will this fit? - 6 Speed Gearbox
It will fit as crasher says but the TDi ratio’s won’t suit the engine, you need one from a petrol engine car. I’ve seen a few fitted on the original engine mounts and not one of them sat straight, they were all pushed forwards at the gearbox end for the drive shaft and flange to clear the rear gearbox tower. I sat the engine and box on MK4 mounts so the existing towers could be removed from the subframe.
