glen 0 Posted September 26, 2006 the last week or so i have experianced these few probs: far side tyre gone bald on the very edge handling gone shite, as in pretty bad understear and a brake squeaking noise every now and then on near side (when not breaking) ??? any ideas? goes in garage thurs just looking to get a head start cheers Quote Share this post Link to post Share on other sites
rado 0 Posted September 26, 2006 poss wheel brg or summit suspension causing the tracking to be out Quote Share this post Link to post Share on other sites
Guest Posted September 26, 2006 did you have the wheels alligned when you had the konis fitted? they found quite a few problems with mine when I got it alligned, now the steering wheel is 30 degrees off what I thought was centre Quote Share this post Link to post Share on other sites
glen 0 Posted September 26, 2006 yeah had it 4 wheel aligned soon after fitting about 3 months ago... Quote Share this post Link to post Share on other sites
NickVR6 0 Posted September 26, 2006 might be a wheel bearing i guess although it should still handle ok and that would make wirring noise when cornering hard. Could be a track rod or ball joint, it all takes a pounding with that motor up front. whats been replaced and whats original?? If the track rods nacked the front wheels may try to go pidgeon toed, or the oposite i cant remember, that will take the inner or outer edges off the tyres depending which way they are trying to pull Quote Share this post Link to post Share on other sites
glen 0 Posted September 27, 2006 i thinks its a ball joint or track rod... the cars going in for front engine mount tomorrow so get it sorted then, cor i see a big bill coming with 2 tyres the above problem and the engine mount better go rob a bank! Quote Share this post Link to post Share on other sites
Trig 0 Posted September 27, 2006 BJ replacements shouldn't cost much glen, or you could DIY it? You'll need to get it alligned again though. Quote Share this post Link to post Share on other sites
glen 0 Posted September 27, 2006 dam it, that was a waste last time then..... Quote Share this post Link to post Share on other sites
glen 0 Posted September 27, 2006 checked the tyre pressure today and the tyre with the bad wear was down to 25 psi could that of caused it? Quote Share this post Link to post Share on other sites
double-6s 0 Posted September 27, 2006 I've checked my tyres and found them to be as low as 10 psi (!!!) and i've never had that sort of wear. So I doubt thats it? Quote Share this post Link to post Share on other sites
