Nick
Engine temp sender
The temperature gauge in the dash wont register any temp change at all. Is this a possible factor for overfuelling?
To get the temp gauge working i was gonna replace the sender. Is the engine temp sensor the blue one (next to a black one) sitting on top of the part that holds the oil filter?
Cheers,
Nick
hi, temp sender for dash on the vr6 is in the thermostat housing. not sure on the others. yes it is a cause of overfuelling. don't boil it, it gets expensive. sender for vr6 from stealers is £26
