robbo101
Electric Problems
Right My Vr6 will not start. Ignition lights come on but the starter does not turn over the engine. Also ABS light stays on constantly and my Cd player has stopped working. Thinking might just be a fuse any Idea which or poss a relay.
Best mention I have had the entire dash out to do the heater Matrix. car did start with most of the dash in and was listening to Cd's only when I finnished fitting the lower panals and glovebox did I notice no CD playing and then a non starter. :cry:
has someone got a idea where to look first fuse or relays or somewhere else.
Cheers
Paul
Have you lost any other circuits such as heater blower, wipers, headlights? If so there is a problem with the load relief switching which could be the relay (position 4) or the ignition switch.
Best wishes
RB
